3-Newcomer
Apr 17, 2023 3:25 AM UTC
Delete the ChangeRequest, the Attachments entity file is not deleted
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030
Translated Subject from traditional chinese to english using google translate on 17 April 2023 at 9:53am IST. Translated by vnamboodheri
Old Subject - 刪除ChangeRequest,Attachments實體檔案沒有被刪除
HelesicPetr
Apr 19, 2023 5:41 AM UTC
Hi @DK_10184244
It is common behavior of Windchill.
The FileVaults are not deleted instantly if the object is deleted from Windchill.
The files stay in vault for a week and after that time by the remove unreferenced files are deleted.
The article describes how to do so> CS56539
More information about unreferenced files> CS294987
PetrH
HelesicPetr
Apr 18, 2023 12:40 PM UTC
Hi @DK_10184244
What do you mean "attachment entity" ? Do you mean a file vault of attachment file?
Or do you mean the objects linked as a affected object table?
If vault file, then it is normal, you need to run remove unreferenced files from vault.
If affected objects it is normal, if the change request is deleted this action do not affected other objects in the system. \
PetrH
3-Newcomer
Apr 19, 2023 12:39 AM UTC
hi @HelesicPetr
I mean vault file of  attachment file, how to remove these file? Use API or something?
thank!
HelesicPetr
Hi @DK_10184244
PetrH
