Delete Version B after rejected promotion?
  • August 17, 2012
  • 1836 views
Scenario: while working with the CAD part, a version B was created when it should have remained version A (still novice at this). However, that .prt file was part of 2 promotion requests (both rejected so the WT part and all of its dependents are still "in work") and now when I try to delete version B of the CAD part, I get the error that it's part of a promotion request baseline. I've gone to the actual baseline and removed version B from that, but that doesn't seem to have helped. It appears that the fact that it's in the promotion request history is the issue, however I don't see any way of deleting old promotion requests in the history that have already been rejected. I've tried renaming the CAD part in the hopes that a new name would break the association with the baseline promotion history, but that didn't get me any further.
My question is: what is the best way to delete version B so I can get back to A? Is it possible at all?
Thanks in advance for your help.
22-Sapphire I
August 17, 2012
You do in fact have to delete all the promotion requests associated with Rev B (not just the baseline created automatically with each promotion request). No other way to delete Rev B iterations.
RocketMan1-VisitorAuthor
Mike, thanks so much for confirming. Unfortunately this is complicated a bit by the fact that those promotion requests have since been rejected. Thus, I'm having difficulty navigating to the place where rejected requests "go to rest" so to speak. I would have thought I could find it in the part history but nothing seems to show up regarding promotion requests. Is there a way to pull up old promotion requests that have been rejected already?
Thanks again!
22-Sapphire I
August 17, 2012
The request itself does not change location when it's state changes. Navigate from the product data to the request via the History tab, Version History table - there is a link there to the Request under "Authorization" column.
