Dec 14, 2011 2:22 PM UTC
Deleting old unsused product on Winchill 9.1
We need to purge and delete some old product that we wont use anymore on our Windchill 9.1,
How can we do ?
thank you
yoann
Dec 15, 2011 10:31 AM UTC
Hi Yoann
Be careful when you use Purge in Windchill
You Should be a Windchill Admin and should be aware of the Purge Function
To purge go to
Organization>Utilities>Purge Manager
Open Collection Criteria Manager
Create a New Collection
Specify Name and Description and Click Next
Include and exclude Products
When You include a product you can go to the folders of the product(Include and exclude Sub-Folders)
After selection of product and folder click Next
Select Criteria
Choose Object Type
Click Finish
Click Close
In Purge Manager Click New Job
Find/Select Query you have just created
Choose the query and click Ok
Click Next Next Next with suitable options
Then check the Status of Purge
Regards
K.Mahanta
YBallini1-VisitorAuthor
Dec 15, 2011 5:05 PM UTC
when I try to create the Query,
and when I've selected the product
I've to select criteria but I don't Understand: I want to erase the whole product,
and if I try to select criteria it sais that
"criterias must have valid type of object"
thanks for your help
Dec 16, 2011 5:43 AM UTC
Hi
After you select a product and click next
A new window will popup (NEW QUERY)
In this screen there is Criteria selection option
In this dropdown select
1.Iteration and press add
2.Version and press add
3.Object type and press add
Then these options will be added in the screen
lteration gives you option to choose how many lteration you want to keep
Object type gives you option to choose which type of document you want to purge.
Click find and choose Document or EPM Document Or Part you want to purge
Version- choose All but Latest
Then Click Finish
I hope you can do now
Regards
K.Mahanta
Jan 20, 2012 5:23 PM UTC
If purge is not helping, as a workaround you can prevent users from accessing required Product(s).
Refer https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS17795
