Apr 10, 2015 11:33 AM UTC
Description tools on file creation
Hi All,
We currently have our Windchill set up to prevent duplicate part numbers from being created. I'm looking to further evolve our systems to remove the need for an external part number database altogether. Are any of the following achievable with Windchill 10.1, please:
  • Preventing duplicate part descriptions;
  • Setting a custom field for an abbreviated description that can also prevent duplicates;
  • Setting both fields up to prevent inputs over a certain length.
Many thanks,
Andy
acoatesAnswer
Apr 24, 2015 12:31 PM UTC
Thanks Lori and Marco.
I've successfully set the limit for a custom global parameter but I am struggling for an inbuilt PTC one. We use "PTC_COMMON_NAME" for our descriptions. Can this be length limited in a similar manner? If not then I can set up a "ghost" new global parameter called, for example "TITLE" and then have a relation that sets "PTC_COMMON_NAME" = "TITLE".
acoates1-VisitorAuthor
Apr 17, 2015 12:14 PM UTC
Quick nudge: can anybody help, please?
23-Emerald II
Apr 17, 2015 10:59 PM UTC
You could achieve the first two using a custom listener/validator that will check whether the description and abbreviated description attribute values are unique when they are updated.
You should be able to set a string-length constraint on the attributes in Type and Attribute Management that can limit the number of characters available for the attribute.
Apr 21, 2015 7:30 AM UTC
Thanks Lori. Is a custom listener/validator something easily set up from within the standard GUI or will It require coding please? I've not come across these before.
acoates1-VisitorAuthorAnswer
TomU
Apr 24, 2015 4:08 PM UTC
You can re-map what Creo parameter populates the Windchill "Name" parameter, but I don't think you're going to be able to limit the length. Creo allows 80 characters for parameters and I believe this is hard coded. I'm not sure what would happen if you limited Windchill to less characters that what Creo allows.
By the way, the mapping between Windchill and Creo is handled in Preference Management under Workgroup Manager Client --> Mapping System Attributes and File Properties. Changing this mapping may require you to modify the download service as well.
Apr 28, 2015 8:46 AM UTC
Thanks Tom. I'll have a play and see what happens!
