6-Contributor
Design in Context for NX
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.18 Referencing to case: CS98538 I need a similar function in NX like for Catia or Creo to use Design Context functionallity. I know, that this is not supported for NX, but i need a way to load filterd CAD Data to NX. Filter used mostly from a Spatial Query. I would be fine when there is a workaround. And maybe you can provide the info when Design Context is available for NX as well Here are the errors that I faced Does not work for NX
Dobi
DobiAnswer
I don’t know if this is version specific to a newer version of WGM but this seems to point to what you’re trying to do via visualizations.
Catalina
Community Manager
Hi ​@ingobleyer
Thank you for your question. 
Catalina | PTC Community Manager
Dobi
Dobi17-PeridotAnswer
