Desktop integration - Windchill 11.0
While publishing a Word document, attributes mapped through DTI are not getting published.
I have a set of 6 attributes mapped to Word document through DTI, the first 3 attributes are set during creation of document and the rest I am setting through workflow.
Only those attributes which are set during creation are published in pdf form.
Has anyone faced the similar issue?
The value of attributes set by Workflow will only appear in the document if you open the document.  How and when is the *.pdf generated?
Hi  SvenVanDroogenb
We have configures worker for document publishing, where in the recipe editor we have set the property DTIProperties: Enable Merge.
As a result in the pdf generated, attributes mapped in the header will be published
Chaithra Sree
you would need to modify PDF Adapter settings via recipe editor and set the property
Rahul
