Jan 3, 2012 6:58 PM UTC
Difference between updatestamp and modifystamp
What is difference between updatestamp and modifystamp?
Dhananjay Sandbhor
Apr 12, 2024 4:54 PM UTC
  • These columns are used to track modification or action performed on an object
    • MODIFYSTAMPA2 - thePersistInfo.modifyStamp
      • Changes whenever an object is modified from a business point of view
      • Stores the date of the last modification made on the object itself like attribute modification, iteration or Check-out
      • Appears in the UI as Modified on attribute
    • UPDATESTAMPA2 - thePersistInfo.updateStamp
      • Changes whenever an object is updated or modified by the Persistence layer
      • Stores the date of the last action made on an object like Subscribe, Set State or Reassign Life Cycle
      • Internal attribute that is normally not exposed in the UI or via supported APIs
