May 11, 2015 8:58 PM UTC
Dimension Layer Missing in Windchill
I can update my drawing with the exact dimesions, but when i see the representation of the same in windchill, its not showing some dimension layers/some incorrect dimensions in it.
Can anyone help me to resolve this.
May 12, 2015 4:42 PM UTC
Is a new representation being created?
Did the same dimension show up on previous iterations?
Has the recipe file been changed?
Is the dimension on a unique layer?
pramkumar1-VisitorAuthor
May 12, 2015 4:48 PM UTC
Yes! New representation has created
No, previous iterations also has same problem, i want the dimension to be as L±1.5, in some iterations this dimesions is missing, and in some iterations it is coming as L±0.5
No.
Thie affected Dimension is a unique layer under one generic part drawing, the remaining dimensions are in different layer under .drw model
May 12, 2015 6:29 PM UTC
Can you post the drawing and model files? Also might want to look at the recipe file. I don't remember off-hand what options are there. Also, what version and package are you running? (9.1 PDMLink?)
