Sep 11, 2023 1:31 PM UTC
Disable or Hide OOTB Change Request Type while creating
Is it possible to disable the OOTB Change Request type while creating the Change Request? I was able to get our custom CR type populate as a default, but I'm looking to disable this OOTB.
HelesicPetr
Sep 11, 2023 1:38 PM UTC
Hello @RG_10753677
Yes you can.
You need to set attribute instantiable to no on the Change Request type.
Be sure that your subtype after change has the instantiable to yes. it is common that the new subtype is driven from upper type.
PetrH
HelesicPetr
Hello @RG_10753677
Yes you can.
PetrH
Sep 11, 2023 2:25 PM UTC
I tried that, but it's not letting me create a new CR anymore, even if the subtype's 'Instantiable' is set to 'Yes'
Sep 11, 2023 2:31 PM UTC
Sorry, It worked now. I didn't realize I have to edit the subtype after changing the OOTB one. Thank you so much.
