Jul 13, 2026 3:17 PM UTC
Document Classification with separate Lifecycle?
Hello, currently working with a company that use Document Classification.
They have one document type for Manufacturing documents but within the classification are selections that should have a different Lifecycle than other selections.
Any idea how this can be done?
I see some help info for “classification binding attribute” but I don’t know if that can be used to define different creation outcomes (OIR).
18-Opal
Jul 20, 2026 6:17 AM UTC
Hi ​@lgrant,
Do you mean that the LCT for Manufacturing Documents should be configured based on the value of the Classification attribute?
lgrant16-PearlAuthor
Jul 20, 2026 11:55 AM UTC
Correct.
It seems like a good idea to start with a few document types and use Classification to sort them into “sub-types” and then as needed, to create more wtDocument sub-types.
At the moment, the company does not have separate attributes for all the selections under the manufacturing wtDocument type but some should have the same lifecycle as the wtPart.
