8-Gravel
September 12, 2012
Document Load From File Attributes
  • September 12, 2012
  • 8 replies
  • 2639 views
I have loaded thousands of documents using the Load From file functionality without problems. I am trying this approach again and am having problems getting the attributes to populate. I have attached a sample file and would appreciate any help. I get no error message in the shell window or in the log file, the object gets created, but attributes don't get populated.
James Little
What version and build of Windchill are you using?
What version of Office created the document?
Is the document in a .doc file or a .docx file.
Thank you,
Ben H. Loosli
USEC, INC.
8-Gravel
September 13, 2012
I appreciate the responses. It is good to be humbled sometimes. Classic example of, if you look at something long enough, it all looks correct. I had copied a script that generates the XML files for my input and somehow missed the End portion of the original script.
James Little
Corning Cable Systems
CAD Administrator
(817) 431-7678 - office
(817) 301-2274 - cell
Jeremiah 33:3 "Call to Me, and I will answer you, and show you great and mighty things, which you do not know."
James,
As part of Ben's questions suggest - are you creating WTDoc's with attached files or is this just "no content" objects?
Looking at your XML snippet it looks like you do not specify a path to the files to upload.
With the loadFromFiles imports we have done we also had a <csvendwtdocument> element after the last <csvibavalue>. Could that be the missing part?
Jorn
The only difference I see between your example and what I did three years ago is the <csvuser> tag is missing.
<csvbeginwtdocument handler="wt.doc.LoadDoc.beginCreateWTDocument">
<csvname>XXXXXXXXXXXX</csvname>
<csvtitle>((null))</csvtitle>
<csvnumber>YYYYYYYYYYY</csvnumber>
<csvtype>Document</csvtype>
<csvdescription></csvdescription>
<csvdepartment>ENG</csvdepartment>
<csvsavein>/Default/Molds/M06262</csvsavein>
<csvteamtemplate></csvteamtemplate>
<csvdomain></csvdomain>
<csvlifecycletemplate>Tool WorkOrder</csvlifecycletemplate>
<csvlifecyclestate>COMPLETED</csvlifecyclestate>
<csvtypedef>com.corning.ToolWorkOrder</csvtypedef>
<csvversion>1</csvversion>
<csviteration>2</csviteration>
<csvuser>wcadmin</csvuser>
</csvbeginwtdocument>
joe bell
CM Application Administrator
22-Sapphire I
September 17, 2012
These code snippets are of course available from within Windchill, but are notorious for having typos, being out date, etc.
It would be great if there was a place on Planet PTC to stash all these after they've been corrected and proven, and possibly commented on.
[cid:image001.png@01CD94AB.1F6A6FC0]
Great idea Mike,
I think the Documents objects at the Planet PTC site could be used for just that.
I just started a minimal (or even measly) attempt for loadFromFiles here:
avillanueva
23-Emerald I
November 19, 2012
I am looking to improve my load processes. Server is Unix which introduces its own complexities but I have some colleagues who have refined this to a request process with their helpdesk. The wrinkle I have is with the Path value which refers to where to look for the primary content file. It appears to be relative not absolute. The last time I played with this I believe it wanted to look the loadFiles/content folder but its been a while.
This is a problem on Unix if the codebase is locked down and under IT control, understandably. I am simply look for a safe drop location for the server to pick up the files from, preferable one that is outside the installation directory.
With the loading I did a while back, here, I created a symbolic link to a temp "vault" location where the couple guys doing the exports out of the old system could throw them. We had to do this because we had quite a bit of data being loaded and didn't want it all in the install directory.
It was just something like $WT/HOME/loadFiles/content/VaultSymLink/documents/docNum/filename.doc in the load file, but we were holding those files just in a directory like /loadVault/documents/docNum/filename.doc
It was all pretty simple and we loaded probably a couple million parts/docs/notes/change objects/etc using this convention for any application data.
Chris
