document rename not updating in task headlines
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020 CPS28
when user updated document with new name it not reflecting in the upcoming task headline but in the subject it does.
Here are the errors that I faced
document rename not updating task headline.when user updated document with new name it not reflecting in the upcoming task headline but in the subject it does.
    HelesicPetr
    Hi @RR_10661622
    You could write a code to do so. Activation event is up to you if it is during a workflow or by listener that is activated during WTDocument rename action.
    PetrH
    olivierlp
    Community Manager
    Hi @RR_10661622 and welcome to the PTC Community.
    I'd suggest to add a reply to your own post with a few screenshots and details. I will help other users to engage and try to help you.
    For reference, here is a guideline to help you: How to Ask a Good Question - PTC Community
    Olivier
    observe the name that E24-025 not updated as E24-045 which is new name of the object.
    Emeritus
    Hello @RR_10661622,
    It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
    Community Moderation Team.
