Jan 29, 2024 2:59 PM UTC
document should not be sent to Publishing
If I want a specific subtype of Document in Windchill not be sent to workers for publishing.
Where exactly we need to make changes in wvs.properties
this is causing two problems:
1. It is keeping AutoCAD workers busy during their execution which delays the others publishing
2. Failed jobs count is high in WVS job monitoring.
Please help me to find a solution for this.
BR,
Prasanna
Jan 29, 2024 3:13 PM UTC
Go to the Site-Utilities and select Publish and Thumbnail Control. In there you can block certain documents from being submitted to the publisher.
Jan 29, 2024 5:41 PM UTC
no no. I accepted as solution by mistake
But Its only for specific documents
I need that entire type of the document to prohibit publishing
avillanueva
23-Emerald II
Jan 29, 2024 6:58 PM UTC
I fixed that for you.
avillanueva
23-Emerald II
Jan 29, 2024 5:33 PM UTC
Didn't we see this under a different post a few weeks back? So these AutoCAD files are handled via WTDocuments right? Have you tried looking at publishing rules?
https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/WVSPublishRules/WVSPublishRulesUsePubRules.html
