Mar 6, 2025 6:32 PM UTC
Document structure to SAP
Version: Windchill 12.0
Use Case: Bill Of Document using ESI
Description:
Hi All,
I want to transfer bill of document(Document structure) to downstream using ESI. How can I able to achive this?
avillanueva
23-Emerald II
Mar 6, 2025 9:32 PM UTC
https://www.ptc.com/en/support/article/CS194303?source=search
This indicates that document links are not supported by ESI. Documents can be published and I do see those in my exports (which I ignore) but linked from docs to docs is not. Suggest adding to Windchill ideas. What is your use case?
