Jul 31, 2017 4:02 PM UTC
Does CreoView support server side "conditional" watermarking?
I am trying to figure out if conditional watermarking is possible: (we want the watermark to = value of PART_CLASSIFICATION for all cases except when that value is UNCLASSIFIED, then we want it to be something like SECRET/RD PENDING REVIEW). The actual label doesn't matter. The main question is: Is it possible to have the watermark feature support logic in terms of which watermark it uses?
Thanks for any help.
Aug 1, 2017 9:20 AM UTC
2-Explorer
Aug 1, 2017 12:29 PM UTC
Which file formats should have the watermark? Is it on a drawing PDF or on Creo view viewables?
If it is PDF out of the box solution is to go by Adobe Experience Manager for which you have to buy a server license from PTC. If you are willing to develop a customization, it is fairly easy using opensource PDFs. I have something which I can share with you
jriely5-Regular MemberAuthor
Aug 2, 2017 8:44 PM UTC
Ideally it should be both PDFs and CreoViewables. Anything you have that is related would be great to look at. Thanks
