Aug 31, 2023 5:12 AM UTC
Does revision of a wtpart can update the new revision reference in all its product structures?
Consider two  scenarios,
1. A wtpart with number 0001, A.1 is used in 7 different product structures.
By revising that wtpart to B.1 , will the new revision B.1 get updated in 7 different product structures as well?
How to achieve this?
2. A 2D drawing with A.1 revision is referenced(associated) by 15 wtparts. by revising drawing to B.1, will this latest revision updated on its associated wtparts also?
How to achieve this.
Thanks in advance.
jbailey
jbaileyAnswer
18-Opal
Aug 31, 2023 9:49 AM UTC
1. No (but you will see the new revision of the part in those product structures when viewing "latest" BOM)
2. No, unless you include and revise the associated wtparts along with the drawing.
jbailey
jbailey18-OpalAnswer
18-Opal
Aug 31, 2023 10:16 AM UTC
Thanks for the reply  jbailey.
Is this the same behavior in latest WC 12 also?
HelesicPetr
Aug 31, 2023 10:21 AM UTC
Yes it is.
If you need to update parent assembly you need to collect it in a revise wizard or change process.
There is function collect parent
Then collect CAD Documents and drawings
sure you will need to update the parent assemblies with drawings.
PetrH
Aug 31, 2023 11:30 AM UTC
Thanks a ton to jbailey and HelesicPetr for your valuable inputs
