Mar 3, 2025 12:09 PM UTC
Download windchill bulk migrator
Version: Windchill 12.1
Use Case: I'm trying to download windchill bulk migrator, but i can't find it in the software downloads page.
Description:
I've seen this article, that says it should be a direct link in the software downloads page, couldn't find it.
I just want to confirm that I don't have access.
Here's a image with the windchill links available to me.
avillanueva
23-Emerald II
Mar 3, 2025 12:26 PM UTC
I do not see that but there is an article in that link you provided that explains why:
https://www.ptc.com/en/support/article/CS46480
You have to have purchased it to have it available. Also, this is only available to service providers, not end customers.
avillanueva
23-Emerald II
VR_400014-AlexandriteAuthor
Mar 3, 2025 12:46 PM UTC
I do work for a company that sells PTC software, but if it's not there then I see what I can do.
Thanks for the quick answer.
Mar 4, 2025 2:59 AM UTC
Check with your Admin if you have different SCN for WBM. Usually there is a different one, you can configure your PTC ID with that SCN then you will be able to see it in the downloads
