6-Contributor
Feb 9, 2015 7:47 AM UTC
Downloading EPMDocuments from server side
Hi
As we are aware that the download option for EPMDocuments has been removed by PTC. I got help from the posts in the community, i tried to execute the utility given in the thread (http://communities.ptc.com/thread/53101) . But seems it not working properly as expected. In my case it's more simpler as I need to download all the EPMDocument. When I execute this utility from the shell it downloads the EPMDocument, i.e. ".asm" file into ".ol" format and ".prt" file into ".log" file to my local drive. Whereas I don't want the file format to get changed once it gets downloaded on my local drive.
I received suggestions in the thread for downloading EPMDocument from the standalone windchill.But my requirement is to download it from the server side/vaults.
Can some one please help or suggest me to download it form the Windchill server/vaults.
Thanks.
Feb 9, 2015 9:01 AM UTC
Packages effectively allow you export documents in a managed collection.
In addition. If you use Windchill Parts then you can export the related CAD documents of a part configuration using Export Manager
http://support.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=ExportImportExportAbout&action=show
For Creo and some other supported CAD apps you can also export from a workspace.
http://support.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=CADxToolsMenuCADDataImportExportAbout&action=show
rml6-ContributorAuthor
6-Contributor
Feb 9, 2015 9:40 AM UTC
Thanks for the help Darren.
It would be really great and helpful if you suggest a way to automate the process to download only EPMDocument by writing windchill utility that can help me to download the files from the windchill server side directly.
Thanks.
