Jun 15, 2015 8:44 AM UTC
Drawing distribution and release process using Windchill
Dear Windchill experts, I am trying to setup a drawing distribution and release process through Windchill, can anyone share some best practices on this topic if you have implemented the same in your company ?
Athmanand
Jun 16, 2015 12:30 PM UTC
Hi
I have done a few things but it depends on many things.
For me in the past the required was so.  Non Windchill users needed to be informed that certain documents (Office or CAD) were released. I have used my Windchill Login and created Subscription. I have then set up rules in my Email to automatically forward those notification emails . I had ensured they could easily be identified.
We also used a third party software which automatically created pdf of those freshly released documents outside of Windchill in a share folder.
No one had a direct access to the share folder and a html interface was designed to access "manually" the document by entering the document number.
The email notification also contained a link to the pdf.
Consequence:  Non Windchill users were notified within seconds that a new document was released and they could click on the link of the email to open the pdf directly.
There was a drawback, sometimes they received notification for documents having no interest to them but this was quite rare.
Advantage. Investment of 10kUSD for the Third Party software allowed as many users as wanted to be informed and read the released documents
Hope this helps
Jun 16, 2015 1:58 PM UTC
Look into the Change Management workflows (Change Notice/Change Activity) for your release process. I've implemented it and have been very happy with the results. It was fairly easy to tailor to our process once I got the hang of manipulating the workflow templates.
Anand1-VisitorAuthor
Jun 18, 2015 5:30 AM UTC
Dear Chris,
Thanks a lot for your inputs.... can you give me few details on the third party software which you were mentioning ?
Jun 18, 2015 6:22 AM UTC
Dear Don,
Thanks for your comment, We are also looking to adopt the change management workflows,
When you are releasing a drawing in Windchill, how do you capture the approver and reviewer informations on your drawing ?
Athmanand
Jun 18, 2015 2:21 PM UTC
Hi Don,
I know it is an old practice to have the Created By, Approved By and Reviewed By (as well as the date) but to me this should not be required.
It can be complex to put this in place. I had a similar requirement in the past in my company. It took me a long time to convince people it was not required as they should check PDMLink if they need to know.
From production standpoint. It should really no matter who created it, who approved it etc... they should only be concerned with insuring that what they get is what they need, ie an approved drawing. Who approves it is not relevant to them.
For audit purposes, well everything is in Windchill,
The other requirement I had was that some sites were used to list the changes on the 2 DRW. Here again, it is a duplication of information as it exists in Windchill (should exist if Windchill is used correctly).   I am must say that while I thought I have won that battle (no history table on the drawing) after about 3 years a new manager came and told the designer to do include the version history table.  I could not stop them as there is no authorisation to stop that but I really believe it is a waste of time.  His call after all......
Nonetheless, this does not answer your original question and I hope someone will tell you how to do it. But this can be tricky because what do you actually release, the drawing the model, the wtpart ?........
Jun 18, 2015 2:32 PM UTC
That wasn't responding to me, but still useful information.
Jun 19, 2015 1:09 PM UTC
Dear Chris,
Can you give some more details on creating a soft attribute and calling that information onto the drawing ?
Are you speaking in context of layout files ??
Athmanand
Jun 22, 2015 3:32 PM UTC
Dear Athmanand
I was talking about drw files. But in theory it should not be that different with layout files
For the drawing, create a soft attribute for EPMDocument,  when you create the drawing in ProE, create the parameter which will be matched during checking in.
On the drawing call the parameter &PARAMETER:D    : D  because if it is a drawing.
Best regards
