Drawing Losing Links to Parts Upon Revise
- October 16, 2014
- 1 reply
- 1132 views
10.1 M040
I am observing the following behavior when an EPM Document drawing is revised from A to B.
Data Setup:
1. Models: Generic with 3 instances.
2. Drawing: 1 instance is detailed on the drawing which creates a dependency in Windchill to the generic and the instance. There is no dependency between the other 2 instances and the drawing.
3. Upon checkin of the models and drawing, WTParts are created and auto-associated. A preference is set to create a Content link from the WTPart for 1 instance and the drawing.
4. A user must manually create a Content link between the other 2 WTParts and the drawing.
[cid:image002.png@01CFE938.D9FB7710]
Behavior:
1. In our business, we allow the engineer to revise the drawing only to correct spelling mistakes and the like (NON form/fit/function).
2. When the drawing is revised, all of the Content links to the WTParts are lost. Windchill only shows a Calculated link from 1 WTPart to the drawing because of the dependency link to the instance.
[cid:image003.png@01CFE939.440A3100]
Does anyone know of a way to carry forward the Content links from the drawing to the WTPart when only a drawing is revised?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image004.jpg@01CFE939.5EE8B370]
Data Setup:
Behavior:
