Mar 12, 2015 4:25 PM UTC
Drawing references
I have a drawing with an assembly as model.
In the Windchill section "associated object" / "references", I can see parts, which one do not have any relation with the drawing or the assembly.
Where could I find where these references come from ??
(I cannot delete these part because they are link to the drawing ...)
23-Emerald II
Mar 24, 2015 12:01 AM UTC
It's possible that these files were referenced by the drawing at one time and the references are now being maintained as legacy relationships. Take a look at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS28858 and see if that is helpful in getting rid of the relationships. If you are able to break the link you will most likely need to purge the earlier iterations of the drawings/part to be able to completely delete the part from Windchill.
