Feb 28, 2025 11:15 AM UTC
Drop-Down Filter based on Manual Value Enter
Hi Guys,
I have an attribute for which I added an enumeration drop-down list containing over 4000 items. It's default to select, based on scrolling. Is it possible to enter a value manually in the attribute box and filter the list based on the entered value.
Aj
avillanueva
23-Emerald II
Feb 28, 2025 12:28 PM UTC
What kind of constraint are you using? Is it Legal or Suggested Value List? Also why so many? This will make it impossible for users to use. You might want to deploy a cascading attribute to cut the list to two questions.
Your screen shot seems to indicate your asking the user for a Unit, possibly of another attribute V. Have you thought of using a unit based attribute?
Feb 28, 2025 12:39 PM UTC
Hi, @avillanueva thanks for the replay,
Please find the below details.
Attributes are string type.
Those are customer names & codes based on SAP information & the above image it's just an example.
Enumerated Value List + Global Enumeration Used
Aj
