Dropbox question
Here is our scenario. Folder location contains objects. WC class comes
to pick them up, creates a document in Windchill, etc. We'd like this
automated. Our assumption was to use a cron job (actually, pretty
certain). Alternatively, we could use a job scheduler in WC. I've seen
some pros and cons listed, but to remove the question to a slightly
higher view, how is anyone else accomplishing this? I.e. files are
created outside of PDMLink on a (very) regular basis and documents need
to be created (that's a lot of user interaction). I.e. work flow robot
instead or......? The windows explorer drag 'n drop interface isn't an
option for us, either (though when it's in a better form it definitely
looks intriguing).
I'm new to the wc dev environment, so it's quick for me to get lost in
the weeds and miss a better/easier solution.
Thanks!
Brian
PS: I'm sending this a third time as it never showed up prior. I
apologize if it was just stuck in a queue the last day or so and there
are three of these. Stupid name server changes.
looks intriguing).
Thanks!
Brian
