11-Garnet
Jun 3, 2026 1:51 PM UTC
During O2S migration got error Creating create_ddl_wt failed: "create Database DDL failed"
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020 During installation of O2S migration utility we encountered an error message Creating create_ddl_wt failed: "create Database DDL failed" . Source database is Oracle 12c the target database is SQL Server 2017 this is part of attempt to bring WcT 11.0 on Oracle to WcT 13.1 on SQL Server. Here are the errors that I faced Creating create_ddl_wt failed: "create Database DDL failed" DEBUG 2026-06-03 15:38:25 - ------------------------------------------------------------------------------- DEBUG 2026-06-03 15:38:25 - ==== Switching Windchill data store to Oracle finished sucessfully ==== DEBUG 2026-06-03 15:38:25 - ***************************************************************************************** DEBUG 2026-06-03 15:38:25 - Creating create_ddl_wt failed: "create Database DDL failed"
nbojceticAnswer
11-Garnet
Jun 4, 2026 10:23 AM UTC
Hi BryanK,
I tried that it did not work. Eventually I found solution and it is to install CPS23 and the use O2S with CPS23.
This solution works, so far, I am waiting for another curve ball from PTC.
Best reagrds!
Nenad
Jun 3, 2026 9:33 PM UTC
This may be the issue.
https://www.ptc.com/en/support/article/CS320861
nbojcetic11-GarnetAuthorAnswer
11-Garnet
Hi BryanK,
Best reagrds!
Nenad
