Nov 29, 2018 3:43 PM UTC
Dynamic Routing Option
Is there a possibility to set the list of routing options of a task depending on a variable when starting a task?
I only found the "tally" method to set up events automatically but that does not seem to help in my use-case.
Use-Case:
Skip a routing option when a process/task variable has a specific value.
Pre-Condition / dependend variable:
                boolean ir_autocreated;
Routing in Task:
A
B
C
X
For Routing „X“ there shall be valid:
IF ir_autocreated == true THEN Routing Option “X” shall be "invisible" / not selectable in the task
Thank You in advance
Harald
HelesicPetr
Aug 26, 2022 12:33 PM UTC
Hi @hbock
So do you need to specify routings on some rules in a user task right?
So create a condition in a Workflow that controls what you need and define routs for several users tasks with different routings as you need.
Then just run the task with correct routings that are shown to a user
PetrH
2-Explorer
Mar 15, 2019 8:20 PM UTC
Hello Hbock,
Did you manage to implement the routing options that you have described ? I am looking at a similar scenario and wanted to know how to disable or hide a routing based on some logic.
Much appreciate your response if you succeeded in implementing the same.
hbock10-MarbleAuthor
Mar 18, 2019 2:16 PM UTC
No, no success so far.
I was contacted by a PTC person form technical support, but also on this channel no news
Best Regards
Harald
7-Bedrock
Aug 26, 2022 11:14 AM UTC
Hi!
Any news about that topic?
Best regards,
Mike
