Jun 15, 2018 8:52 PM UTC
Editing Attributes on the Links of Change Relationship Tables
This is a topic in the Windchill Help: http://support.ptc.com/help//windchill/wc111_hc/whc_en/index.html#page/Windchill_Help_Center%2FWCCG_BusLogicCust_EditAttrChangeRelTable.html%23.
Anyone ever successfully made this customization to the Affected or Resulting objects tables on the Change Notice? I need help with the data utility.
Jun 19, 2018 2:55 PM UTC
Did you check out the Tips and Tricks from JeffZemsky
Jun 22, 2018 1:31 PM UTC
I've gotten part of the way through this but am still having problems with the form delegate. I can enter a value in a textbox for my string attribute on the change task editing page, so it seems like my data utility is working. But once I select finish, the value entered isn't persisted back to the Change Task. I wrote a form delegate and registered it using the wt.properties property com.ptc.netmarkets.util.misc.defaultActions as described in the help. This seemed like the better-documented part of the example, but I can't get it to work.
package ext.change;
import com.ptc.windchill.enterprise.change2.forms.delegates.ChangeTaskAffectedItemsFormDelegate;
import wt.change2.ChangeItemIfc;
import wt.fc.collections.WTCollection;
import wt.util.WTException;
import com.ptc.windchill.enterprise.change2.ChangeLinkAttributeHelper;
import com.ptc.windchill.enterprise.change2.beans.ChangeLinkAttributeBean;
import wt.util.WTPropertyVetoException;
import com.ptc.core.meta.common.UpdateOperationIdentifier;
import com.ptc.core.lwc.server.PersistableAdapter;
import wt.change2.WTChangeActivity2;
import wt.change2.ChangeRecord2;
import com.ptc.windchill.enterprise.change2.ChangeManagementClientHelper;
import java.util.Iterator;
public class MyAffectedItemsFormDelegate extends ChangeTaskAffectedItemsFormDelegate {
 * This method is used to post-process attributes on the change activity
 * and change records.
	@SuppressWarnings("unchecked")
	@Override
	protected WTCollection processLinkAttributes(ChangeItemIfc item, WTCollection binaryLinks) throws WTException {
		WTCollection modifiedLinks = super.processLinkAttributes(item, binaryLinks);
		if (binaryLinks != null && !binaryLinks.isEmpty() && item instanceof WTChangeActivity2) {
		 // The link bean has knowledge of how of link attributes and supports the JCA interfaces.
		 ChangeLinkAttributeBean linkBean = ChangeLinkAttributeHelper.getChangeLinkAttributeBean();
		 linkBean.setFormData(getObjectBean());
		 for(Iterator<ChangeRecord2> iter = binaryLinks.persistableIterator(ChangeRecord2.class, true); iter.hasNext(); ) {
			ChangeRecord2 record = iter.next();
			// The getTableDataValue() will get the attribute from the FORM data supporting any specific change table handlers
			String value = ChangeLinkAttributeHelper.getTableDataValue("estimated_cost",
					ChangeManagementClientHelper.getReference(record.getChangeable2()), linkBean);
			// The new LWC API for getting and setting attributes.
			PersistableAdapter lwc = new PersistableAdapter(record, null, null, new UpdateOperationIdentifier());
			lwc.load("estimated_cost");
			Object currentValue = lwc.get("estimated_cost");
			// Only set the attribute if it is different than the current value
			if(( value != null && currentValue != null && !value.equals(currentValue.toString())) || (value == null && currentValue != null) ) {
			 lwc.set("estimated_cost", value);
			 lwc.apply();
			 // calling apply() will require verification, however since this form delegate is setting the changes we can set it as verified.
			 try {
				record.getPersistInfo().setVerified(true);
			 } catch (WTPropertyVetoException e) {
				e.printStackTrace();
			 modifiedLinks.add(record);
		return modifiedLinks;
20-Turquoise
Jun 22, 2018 1:52 PM UTC
The Windchill java docs show persisting the updated object with:
PersistenceHelper.manager.modify(my_persistable);
I see you using the apply() method but not persisting the updated object. Have you tried this?
lwc.apply();
PersistenceHelper.manager.modify(record);//add this?
Jun 22, 2018 2:28 PM UTC
Thanks for the suggestion, but I'm getting the same thing - doesn't persist back to Change Task.
