7-Bedrock
Apr 23, 2025 6:11 AM UTC
Effectivity Delete Audit
Version: Windchill 12.1
Use Case: Is there a method to track the deletion history of effectivity in WTPart? For instance, if I have a WTPart A and initially set 'xyz' as its effectivity, but later someone deletes this effectivity and either sets a new one or leaves it empty, is there a way to identify who performed the deletion? Thank you, Pravin
Description:
Apr 23, 2025 7:39 AM UTC
Useful article - "API to retrieve associated Effectivities of a WTPart in Windchill PDMLink": https://www.ptc.com/en/support/article/CS152894
Catalina
Community Manager
Apr 29, 2025 2:44 PM UTC
Hi @PS_10220246 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Best regards,
Catalina | PTC Community Manager
