May 16, 2024 9:17 AM UTC
Email Notification from Windchill Workflow
Hi Mahesh i have one business requirement : requirement as below -->
1) One String custome attribute we have on PromotionRequest.
2) While creating PromotionRequest creater will add the emails in that String attribute which are comma separated.
3)And I need to get that attribute values (Emails) and i have to notify those User using mail with customised subject and mail body.
So I need a help to achieve this I am very new in Workflow customization.
HelesicPetr
May 16, 2024 9:22 AM UTC
Hi @@_1647
You need to write a code to read the attribute with the separator in the String and believe that user input is correct 😄
PetrH.
@_164713-AquamarineAuthor
May 16, 2024 9:57 AM UTC
Yes I know the way to get attribute values using PBO  :
com.ptc.core.lwc.server.LWCNormalizedObject obj = new
com.ptc.core.lwc.server.LWCNormalizedObject(primaryBusinessObject,null,null, null);
obj.load("theAttribute");
Object softAttribValue = obj.get("theAttribute");
if (softAttribValue instanceof String) {
yourvariablee  = (String) softAttribValue;
But I want use this varibale values to send emails dynamically that I need
HelesicPetr
May 16, 2024 10:04 AM UTC
Hi @@_1647
So now use substring to divide the email address from the string and send the emails to them
use  for cycle to add participants one by one
localEMailMessage.addRecipient(participant);
PetrH
