Jun 21, 2023 6:08 PM UTC
Empty geometry (Bulk Items) components quantities in multiple assemblies
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
I need instructions on how to handle components in assembly without a geometry (e.g. paint, oil, tape,...). I found some examples in Internet that Creo handles this through Bulk items, however I was not able to create different quantities between multiple assemblies driving the quantity from CAD. In SOLIDWORKS this is possible to handle using Virtual Components, however even enabling virtual components in Windchill the result is not achievable.
Jun 21, 2023 6:15 PM UTC
Bulk Items typically do not have a quantity listed in the drawing BOM but a AR (As Required) in the quantity field of the repeat region.
Define this in the Repeat Region relations:
IF asm_mbr_type == "BULK ITEM"
quantity = "AR"
ELSE
quantity = rpt_qty
ENDIF
Add the Parameter:
QUANTITY
In the BOM table use &asm.mbr.quantity for the repeating value in the Quantity column.
Jun 21, 2023 6:20 PM UTC
But how can I achieve the same with SOLIDWORKS? Also this BOM quantity needs to be replicated later to ERP, so at least an estimate needs to be provided.
Jun 21, 2023 6:35 PM UTC
There is no physical quantity with a Bulk Item. it is strictly a place holder for the item.
This is a PTC community for Creo and Windchill and I have no idea how SolidWorks works, never used it.
