Jul 31, 2022 3:42 PM UTC
Entity key is not valid REST odata API
We just upgrade our windchill environment to WC12.   I am trying to use the REST APIs for the first time and just trying using classic asp.
I have been successful using classic asp and doing a "GET" with my http request to retrieve a WTPart or WTDoc object.   I thought things were going well.
I wanted to try getting a BOM structure.  After a lot of reading, I read the GetBOM will be deprecated so I thought I would just try GetPartStructure.
I keep getting "404 error", "Entity key is not valid".   I read in article CS317238 i should be able to send an empty json string (i.e. {} ) .
Here is the sample code from my classic asp.
**** classic asp ****
set HttpReq = CreateObject("MSXML2.ServerXMLHTTP.6.0")
'get the WC token
HttpReq.Open "GET", "http://windschillserver/Windchill/servlet/odata/PTC/GetCSRFToken", False,"username","password"
HttpReq.setRequestHeader "Authorization","username:password"
HttpReq.setRequestHeader "Content-Type","application/json"
HttpReq.Send()
'Load JSON string
oJSON.loadJSON(HttpReq.ResponseText)
wcToken = oJSON.data("NonceValue")
'empty json - no NavigationCriteria to send
postData = "{}"
' GetPartStructure Rest API
HttpReq.Open "POST", "http://windchillserver/Windchill/servlet/odata/ProdMgmt/Parts('OR:wt.part.WTPart:5-023927')/PTC.ProdMgmt.GetPartStructure?$expand=Components($expand=Part($select=Name,Number),PartUse,Occurrence;$levels=max)" , False,"username","password"
HttpReq.setRequestHeader "Content-Length", len(postData)
HttpReq.setRequestHeader "CSRF_NONCE",wcToken
HttpReq.Send postData
The response from the "HttpReq.Send postData" is the "entity key is not valid".
Any insight is greatly appreciated.
Mike
Aug 1, 2022 4:44 PM UTC
Hi @MichaelSchumach
I think the filter has to include max levels, if you try out getpartstructure in the api docs this filter is added to the url by default.
Aug 1, 2022 7:44 PM UTC
Thank you.   I had $levels=max in the POST url.   I took a closer look at 'OR:wt.part.WTPart:234318107'.   I was using an actual WTPart number like 5-023927 when, in fact, I should have been using the ida2a2 number for the WTPart.
Once I got the ida2a2 value from the WTPart table and used it, the GetPartStructure worked correctly.
Thanks for making me take a closer look.
Mike
