TomU
Aug 25, 2017 8:26 PM UTC
Enumerated Value List - How to unselect a previously selected value
I created a new attribute for one object type in Windchill and then added an enumerated value list constraint to it with two values.
Modifying this object in Windchill now gives me the option to leave this property undefined (unset) or select one of the two list values.
Selecting either of the values works fine, and switching between the values works fine, but I can't figure out how to go back to blank (undefined).  Even though there is a blank value displayed, attempting to return to pick it (after having previously selected a different value) is not being permitted.  Windchill just throws an error:
Is there any way around this?  I don't really want an extra "None" entry in my list because "None" and undefined are not the same thing and won't return the same results in a search.
Aug 28, 2017 12:21 PM UTC
This is a long time issue with CAD-Documents
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS22920
TomU
TomU23-Emerald IVAuthor
Aug 28, 2017 1:25 PM UTC
Reported issue is work to spec behaviour. HTML UI Edit attribute action does not allow user to remove attribute. User can remove attribute value in CAD Application.
Unfortunately this attribute is created on the master type (CAD Document Master), so there is no option to remove the attribute in the CAD application (it doesn't exist there.)
Aug 28, 2017 7:13 PM UTC
I don't know why, but PTC doesn't really supports Master Attributes. It starts with the name attribute. If you define a global enumeration for it, it works just in the create wizard. In all other wizard it's being rendered as text field and sometimes even the internal name is being showed. But that's another topic...
You probably would need to customize some action on the EPMDocument itself to clear the Master Attribute. Or you can perhaps extend the edit attribute form processing. But that's probably done with HTML Templating and is also not supported...
