Apr 10, 2025 12:15 PM UTC
EPM Document ICON - UI Layout
Hi Guys,
Can we add the EPM new creation icon in Commonspace itself? Mostly, we can create an EPM in the workspace, and also, when we create a WT Part with we can create an EPM Document. But I want to create an EPM directly in Commonspace.
Aj
avillanueva
23-Emerald II
Apr 10, 2025 1:13 PM UTC
You can access workspaces via the browser to create CAD Documents. So they do not need to be created in a CAD integrated tool or the WGM but you functionality is limited. Must of CAD has associations to other CAD, attributes, etc. You can create objects but they will just have template CAD data inside of them. Real value comes from reading the CAD data to create structure.
Apr 10, 2025 1:27 PM UTC
@avillanueva Thanks for the replay.
We did one customization that is not working in the workspace, but that works in the commonspace for WT Part. We want the same as EPM that we want to create in commonspace.
AJ
joe_morton
Apr 10, 2025 2:47 PM UTC
Maybe use a Save As on an existing EPM? You can do that in Commonspace.
