Oct 27, 2011 8:26 AM UTC
EPMDocument checkout error
The requirement is just to iterate an EPM Document.I am using the below piece of code for iterating an EPMDocument.
// Checkout
wt.vc.wip.WorkInProgressHelper.service.checkout(epmdoc, wt.vc.wip.WorkInProgressHelper.service.getCheckoutFolder(),"Iterated by Administrator");
// Check-in
if(wt.vc.wip.WorkInProgressHelper.isCheckedOut(epmdoc)) {
epmdoc = (wt.epm.EPMDocument) wt.vc.wip.WorkInProgressHelper.service.checkin(epmdoc,");
This works fine for all CAD Documents except for the Family Tables (EPMDocument instances).
In case of Family Tables EPM Document,I get the following error:
C:\ptc\Windchill_9.1\Windchill>windchill ext.Test
Introspection Runtime Mode = true
*************This is the test Class************
at wt.vc.wip.WorkInProgressServiceFwd.checkout(WorkInProgressServiceFwd.java:417)
What am missing out/ doing wrong here?
Selvam
Jan 3, 2012 2:44 PM UTC
Did you finally found a solution for this ? Indeed I am facing the same issue.
Sincerely,
Thibault Magné
Jan 4, 2012 2:56 PM UTC
I currently am facing an error when trying to checkout an EPMDocument
either by I*E or java API.
Here is the error thrown:
com.infoengine.util.IEException: wt.epm.query.QueryException: Parameter
value is null: paramName="baselineId"
The webject I use is as simple as following:
> <ie:webject name="CheckOut-Objects" type="ACT">
> <ie:param name="instance" data="${@FORM[]instance[]}"/">
> <ie:param name="OBJECT_REF" data="${@FORM[]obid[]}"/">
> <ie:param name="GROUP_OUT" data="checkedOut"/>
> </ie:webject>
Using the java API, I try to checkout with the following service :
WorkInProgressHelper.service.checkout()
Does anyone has an idea ? The target of my current customization is to bulk
modify IBA on EPMDocuments.
Thanks in advance,
Sincerely,
Thibault Magné
Jan 4, 2012 3:35 PM UTC
Hello
The check out of EPMDocuments (especially the generic and instances) will
fail if they are not shared to a workspace.
Ideal way of doing is programmatically sharing the epmdocuments in a
workspace and use EPMWorkspaceHelper.manager.checkout().
Please make sure the associations to wtparts are intact after c/o and c/i.
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect, Swasen Inc
swamy.senthil@swasen.com(Email); 909 800 8423(M); 973 324 2729(W); 866
908 6561(F);
Oct 7, 2015 10:44 AM UTC
Hello Swamy Senthil,
I am facing issue while updating content of EPMDocument grammatically.
i am able to create EPMDoc through API, at first time i was able to assign a primary conet file to this EPMDoc.
later when i checked out this epm throgh API and try to modify the content but in this case i got below error.
java.lang.reflect.InvocationTargetException
  at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:800)
  at wt.clients.util.RMIMultiPartPost.performOperation(RMIMultiPartPost.java:257)
  at wt.clients.util.http.HTTPUploadDownload.performUploadOperation(HTTPUploadDownload.java:1357)
  at wt.clients.util.http.HTTPUploadDownload.access$100(HTTPUploadDownload.java:54)
  at wt.clients.util.http.HTTPUploadDownload$HTTPUploadDownloadThread.run(HTTPUploadDownload.java:2728)
Finished uploadFile of [wt.epm.EPMDocument:194491]Caused by: (wt.content.contentResource/66) wt.content.ContentException: Can not add more than one primary content to the object.
please help me out, how i can modify the content file of EPMDoc and check in to Windchill from A.1 to A.2.
Vivek
Jan 4, 2012 3:42 PM UTC
Le 4 janvier 2012 15:41, Thibault Magné <-> a écrit :
> Hi,
> Thanks for this answer, in fact I would like to find a way not to create a
> workspace for each EPMDocument (they can be in different contexts).
> I do not use wtpart association though.
> Here is my actual code, but the workspace consideration is quite an issue
> to me:
> WTPrincipal p =
> wt.session.SessionHelper.manager.getPrincipal();
> WTCollection to_checkout = new WTArrayList(1);
> to_checkout.add(versioned);
> WTSet workspaces = EPMWorkspaceHelper.manager.getWorkspaces(p,
> null); //Here i cannot retrieve a "default workspace"
> Workable copy =
> (Workable)
> wt.epm.workspaces.EPMWorkspaceHelper.manager.checkout (null,
> to_checkout).get(versioned);
> Please take in account that I am not a professional developper (I
> currently am listening java + pdmlink), so feel free to make remarks on the
> code.
> Sincerely,
> Thibault Magné
> Le 4 janvier 2012 15:35, Swamy Senthil <senthils@swasen.com> a écrit :
> Hello****
>> fail if they are not shared to a workspace.****
>> workspace and use EPMWorkspaceHelper.manager.checkout().****
>> Thank you and have a great time.**
>> Best Regards**
>> * Swamy Senthil***
>> * Principal Solutions Architect, **Swasen Inc*****
>> 866 908 6561(F); ****
>> *From:* Thibault Magné [
>> The webject I use is as simple as following:****
>> <ieSmiley Tonguearam name="instance" data="${@FORM[]instance[]}"/">
>> <ieSmiley Tonguearam name="OBJECT_REF" data="${@FORM[]obid[]}"/">
>> <ieSmiley Tonguearam name="GROUP_OUT" data="checkedOut"/>
>> </ie:webject> ****
>> Using the java API, I try to checkout with the following service : WorkInProgressHelper.service.checkout()
>> bulk modify IBA on EPMDocuments.
>> Thanks in advance,
>> Sincerely,
>> Thibault Magné****
Jan 4, 2012 5:04 PM UTC
Hello Thibault
Coin a helper class with few handy methods as in the attached document. Unit
test them and call in appropriate sequence for meeting your requirements.
As you notice in the attached, a named workspace can be retrieved for the
given principal. The attached methods are just for examples.
Please make sure your build code accommodates the same/similar APIs.
for updating the IBA's (not modeled attributes) we have a licensed utility
for R9.1 that performs the updates without check-out/check-in. This is FYI.
Best Regards
Swamy Senthil
908 6561(F);
Jan 4, 2012 5:13 PM UTC
Thanks you, this helps me a lot.
Is there a way to get a "Default" workspace instead of needing to create
one (parameter "name"), depending on the target EPMDoc context's ?
Thibault Magné
Le 4 janvier 2012 17:04, Swamy Senthil <senthils@swasen.com> a écrit :
> Hello Thibault****
> Unit test them and call in appropriate sequence for meeting your
> requirements.****
> given principal. The attached methods are just for examples. ****
> Please make sure your build code accommodates the same/similar APIs.****
> Best Regards**
> * Swamy Senthil***
> 908 6561(F); ****
> Workable copy =
> (Workable)
> code.
> Sincerely,
> Thibault Magné****
> Le 4 janvier 2012 15:35, Swamy Senthil <senthils@swasen.com> a écrit :****
> Hello****
> Thank you and have a great time.****
> Best Regards****
> * Swamy Senthil*****
> 908 6561(F); ****
> </ie:webject> ****
> Thanks in advance,
> Sincerely,
> Thibault Magné****
Jan 4, 2012 5:42 PM UTC
I am unsure why you need a workspace for a specific context.
You can create a workspace "Test" for the product context "Product 1" and
check-out a cad from "Product 2" to the workspace "Test" in Product 1.
Jan 5, 2012 2:17 PM UTC
I simply didn't know it was possible to checkout EPMdoc in a workspace from
a different context. I will try that.
Thank you very much for this,
Thibault Magné
Le 4 janvier 2012 17:42, Swamy Senthil <senthils@swasen.com> a écrit :
> I am unsure why you need a workspace for a specific context.****
> check-out a cad from "Product 2" to the workspace "Test" in Product 1.****
> Regards,
> Thibault Magné****
> Le 4 janvier 2012 17:04, Swamy Senthil <senthils@swasen.com> a écrit :****
> Hello Thibault****
> requirements.****
> Best Regards****
> 908 6561(F); ****
> Workable copy =
> (Workable)
> code.
> Sincerely,
> Thibault Magné****
> Hello****
> Best Regards****
> 908 6561(F); ****
> </ie:webject> ****
> Thanks in advance,
> Sincerely,
> Thibault Magné****
