Mar 11, 2026 12:54 PM UTC
Equivalent usage information has not been retrieved Message
Version: Windchill 13.0
Use Case: When doing a BOM transformation there is a error on the Equivalent usage information has not been retrieved. Why does this appear and how can this be resolved?
Description:
Fadel
FadelAnswer
23-Emerald II
Mar 17, 2026 10:34 AM UTC
When set to 'Yes', the equivalent consumption status of all objects in the structure will be displayed in the 'Equivalent consumption status' columns. When set to 'No', only the equivalent consumption status of leaf objects and sub-assembly objects that are reused between the upstream and downstream structures will be displayed in the 'Equivalent consumption status'
Buiꓘa
Fadel
23-Emerald II
Mar 11, 2026 3:18 PM UTC
Take a look :  https://www.ptc.com/en/support/article/CS407026
Buiꓘa
Mar 17, 2026 10:30 AM UTC
can yo help me understand what does this preference do ?
 Show Equivalent Consumption Status of All Objects in the Structure
When set to Yes what happens and when set to No what happens ?
Because if it is set to No then the error appears in the Bom Transformation. When set to Yes the error is disappearing . What is the meaning of this error ?
Fadel
Fadel23-Emerald IIAnswer
23-Emerald II
Buiꓘa
