Sep 16, 2016 12:20 PM UTC
Error "CAD part is not unique"
I am getting "CAD part XYZ.prt is not unique" error while checking in a particular assembly in Windchill.
In that assembly file there is no CAD part called as "XYZ.prt".
Is there any command to identify which part /feature / layer / subassembly is taking reference from this CAD part XYZ.prt?
or is there any other solution?
Saurabh
cgorniAnswer
Jul 25, 2022 12:10 PM UTC
For more information and possible solutions you can look at a similar thread here
Sep 16, 2016 12:24 PM UTC
Is the part that you are checking in a new object? Can you post a snapshot of the checkin window?
sbisht1-VisitorAuthor
Sep 16, 2016 12:31 PM UTC
Hi Manjunath,
Asm file does not have any sub part called as XYZ.prt.
Mar 6, 2017 4:26 AM UTC
Already in data base same named file is exists, so you may face this problem. if you are not able to see that part, contact admin who have full rights to Windchil
cgorni16-PearlAnswer
