Aug 3, 2023 9:51 AM UTC
Error creating WTObjects shows no attributes in creation wizard
Hello All,
Greetings!
I am sharing a recent issue where I am unable to create any WTObjects on WC. The create new wizard does not show any attributes for type of object.. And the MS Log displays VersionControlException & wt.fc.InvalidAttributeException.
I am attaching related screeshots to help understand this issue.
I would appreciate if anyone might have faced similar issue and could help figure out the cause.
HelesicPetr
Aug 3, 2023 10:17 AM UTC
Hello @Rohaan
Try to check a Type&Attribute Management for the specific object type and control create Wizard if there are any attributes
If not add them, otherwise try to remove the not needed attributes that are not required .
PetrH
avillanueva
23-Emerald II
Aug 3, 2023 2:17 PM UTC
Could this be an issue with Object Initialization Rules? Can you check rules for Parts and post possibly? Indicate which ones are enabled or download the composite rule.
