Error generating REST API ECR in Windchill 12.0
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
We are implementing ERP-PLM linkage using Windchill REST API.
On the ERP side, EngineeringChangeRequest data is configured as JSON and then executed by calling the endpoint of the Windchill REST API.
It operates without problem in Windchill 12.1, but an error occurs in Windchill 12.0.
There seems to be an issue where a problem occurs while importing the CSRF Token.
Here are the errors that I faced
When running on HTTP:
ECR creation failed: Error: Network response was not ok
When running JavaScript (Node.js)
ECR creation failed: {
error: {
code: 'OPERATION_NOT_SUPPORTED',
message: 'The operation is not supported'
Anyway, the situation is fine in Windchill 12.x, but the problem continues to occur in Windchill 12.0.
Translated the text from Korean to English using google translate
Subject - Windchill 12.0에서 REST API를 ECR를 생성하는 과정 중 오류 발생
Body - Windchill REST API를 이용해 ERP-PLM간 연계를 구현하고 있습니다.
ERP측에서 EngineeringChangeRequest 데이터를 JSON으로 구성한 후 Windchill REST API의 엔드포인트를 콜해 실행하고 있습니다.
Windchill 12.1에서는 문제없이 동작하고 있으나, Windchill 12.0에서 에러가 발생하고 있습니다.
CSRF Token을 가져오는 중간에 문게가 발생하는 이슈가 있는 것 같기도 합니다.
HTTP에서 실행할 경우:
ECR 생성 실패: Error: Network response was not ok
JavaScript를 실행할 경우 (Node.js)
ECR 생성 실패: {
error: {
아무튼, Windchill 12.x에서는 문제없는 상황이나, Windchill 12.0에서 문제가 지속적으로 발생하고 있습니다.
 - By Community Moderation Team
    Community Moderator
    March 28, 2024
    Hi TH_10814171,
    Thank you for your question.
    I’d like to recommend to bring more details and context to your initial inquiry.
    It also helps to have screenshot(s) to better understand what you are trying to do in your process.
    Community Moderation Team.
