Mar 2, 2026 12:12 PM UTC
Error getting the value from the KeyStore file
Version: Windchill 12.1
Use Case: Errors in logs at Windchill startup, but it starts.
Description:
This has been asked before, but as there's two different related articles I'm asking again.
There's errors in logs at Windchill startup:
com.ptc.paa.config.keystore.PAAKeyStore  - Error getting the value from the KeyStore file java.security.KeyStoreException: Could not load keystore file.
However, Windchill starts and runs fine.
There's two different solutions. One says to delete files and restart, another says to run -ant to recreate keystore. Which is enough?
https://www.ptc.com/en/support/article/CS287849
https://www.ptc.com/en/support/article/CS110492
Fadel
23-Emerald II
Mar 2, 2026 2:00 PM UTC
Mar 2, 2026 6:35 PM UTC
It's like cache files. If you don't create them from ant command it will get recreated on startup.
