Mar 8, 2017 8:22 AM UTC
Error in when starting the Server Manager:ERROR [main] wt.manager.ServerManagerImpl - Failed to create JmxConnectInfo!
Hi all,
I am new to Windchill and also to configuring Windchill to have multiple MS and BGMS.
I've set up a new configuration with 2 MS and  3BGMS.
Right now when i start the Server Manager i get the following error:
2017-03-08 08:53:51,915 INFO  [main] wt.server.manager.startup - Registry created: RegistryImpl[UnicastServerRef2 [liveRef: [endpoint:[ch-s-0008278.ch.abb.com:5002,wt.boot.WTRMIMasterSocketFactory@1e240](local),objID:[0:0:0, 0]]]]
2017-03-08 08:53:51,930 ERROR [main] wt.manager.ServerManagerImpl - Failed to create JmxConnectInfo!
sun.management.AgentConfigurationError
  at wt.jmx.core.remote.ConnectorBootstrap.checkPasswordFile(ConnectorBootstrap.java:570)
  at wt.jmx.core.remote.ConnectorBootstrap.startRemoteConnectorServer(ConnectorBootstrap.java:374)
  at wt.jmx.core.remote.ConnectorBootstrap.initialize(ConnectorBootstrap.java:281)
  at wt.jmx.core.remote.ConnectorBootstrapUtil.initRemoteJmxConnectorInternal(ConnectorBootstrapUtil.java:97)
  at wt.jmx.core.remote.ConnectorBootstrapUtil.getRemoteJmxUrl(ConnectorBootstrapUtil.java:70)
  at wt.jmx.core.remote.ConnectorBootstrapUtil.initRemoteJmxConnector(ConnectorBootstrapUtil.java:51)
  at wt.method.jmx.JmxConnectInfoHelper.<clinit>(JmxConnectInfoHelper.java:51)
  at java.lang.Class.forName0(Native Method)
  at java.lang.Class.forName(Class.java:191)
  at wt.manager.ServerManagerImpl.<clinit>(ServerManagerImpl.java:123)
  at wt.manager.ServerManagerMain.startServerManager_internal(ServerManagerMain.java:367)
  at wt.manager.ServerManagerMain.run(ServerManagerMain.java:295)
  at wt.manager.ServerManagerMain.main(ServerManagerMain.java:225)
Do you have any idea how i can fix this?
Alex
2-Explorer
Mar 8, 2017 4:50 PM UTC
Looks like one of the startup commands has incorrect values. Could you let us know the changes you made to the properties to add more MethodServer or may be attach the wt.properties file?
2-Explorer
ailut1-VisitorAuthor
Mar 9, 2017 6:22 AM UTC
Hi Kumar,
Indeed there was a problem with the Server Manager "wt.manager.cmd.ServerManager.jmx.args" property. The -Dwt.jmx.rmi.minPort and -Dwt.jmx.rmi.maxPort values were not correct. For now I removed this property and will update the .xconf file when there is more data about what the client needs.
Alex
Jan 7, 2020 6:49 AM UTC
good work bro
it is working for me
Thanks a lot the help.
