May 23, 2024 9:22 AM UTC
Error in windchill PDMLink 12.0 installation
Version: Windchill 12.0
Use Case: Came An error while installing Windchill PDMLink 12.0
Description:
Hi Everyone,
I was having an error while installing windchill PDMLInk 12.0
pls suggest me the solution
Thanks and Regards,
Lav
shussainiAnswer
May 23, 2024 10:01 AM UTC
Seems you are missing on the Info*Engine and Windchill REST services CDs. You can download the required CDs from the software downloads page. IF already downloaded, then make sure the downloaded zips are extracted in the staging folder. The staging path is the location where you have downloaded and extracted ALL the CDs.
Hope this helps.
regards
~Syed
shussaini16-PearlAnswer
Hope this helps.
regards
~Syed
