11-Garnet
Mar 9, 2023 6:30 PM UTC
Error installing SolrServer 12.1
Installing SolrServer on a test\dev separate server, and getting the following error:
java.nio.file.FileSystemException: C:\Users\aaworourke\AppData\Local\Temp\2\PTCSOLNINSTALLER_PtcInstall.log: The process cannot access the file because it is being used by another process.
According to Task Manager, nothing is running connected to Solr. We are using Amazon Corretto 11 for our java environmental variables. Just curious if anyone else has seen this. Many thanks in advance!
jbailey
jbaileyAnswer
18-Opal
Apr 26, 2023 11:34 AM UTC
Did that fix the issue?
avillanueva
23-Emerald II
Mar 9, 2023 8:11 PM UTC
Was there a previous failed attempt at running the PSI installer that is remaining running?
borourke11-GarnetAuthor
11-Garnet
Mar 9, 2023 8:15 PM UTC
No, and I bounced the server to be sure.
jbailey
18-Opal
Apr 25, 2023 10:50 PM UTC
A little trick I use with SOLR specifically is to find the PID (Process ID by which one has locked up the port)
Netstat -a -o | find “8085”
Returns a line for that port, and use the PID returned in the next command
Taskkill /f /PID “pid from netstat”
11-Garnet
Apr 26, 2023 11:31 AM UTC
Many thanks!
jbailey
jbailey18-OpalAnswer
18-Opal
