Jan 29, 2026 4:18 PM UTC
Error message: java.lang.NullPointerException" in Windchill Enterprise Systems Integration
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.2
Here are the errors that I faced
    Fadel
    23-Emerald II
    Jan 29, 2026 4:35 PM UTC
    Can you attach the stack trace from the Method server log , we can't do much with
    Buiꓘa
    Jan 29, 2026 4:53 PM UTC
    I have attached the log, it is info engine task issue, it is not getting invoked. the payload is not generating
    18-Opal
    Jan 29, 2026 4:42 PM UTC
    Hi @KP_12912900,
    Where exactly are you encountering this error?
    Could you please attach some screenshots along with the Method Server logs?
    Jan 29, 2026 4:49 PM UTC
    18-Opal
    Jan 29, 2026 4:54 PM UTC
    Your custom class is throwing a NullPointerException.
    You will need to review and correct the logic.
    ext.intel.integration.renderer.ECMPartRenderer.adjustPartElement(ECMPartRenderer.java:165)
