Sep 17, 2024 10:06 AM UTC
Error when Launching Creo View in windchill 11.1
Hello All,
I Have this message "Error Occurred communicating with Windchill ..." when I try to launch creo View in windchill 11.1 (M020) . I follow the CS415933 (https://www.ptc.com/en/support/article/CS415933)for using the TLS V1.2 in apache Config but it still doesn't work.
Have you an idea ?
thanks a lot
Sep 19, 2024 8:25 AM UTC
I Find The solution with IT: CRL file was expired on our system.
avillanueva
23-Emerald II
Sep 17, 2024 12:24 PM UTC
Is this a new problem or something that started after you switched to HTTPS?
Sep 17, 2024 2:08 PM UTC
No I don't switch to https recently and it works before. I don't know since how many time, users are not always on creo view.
But on our information system, people from network and security have made some change recently (new firewall restriction, new antivirus policies, new proxy rule,etc..) I think problem is here but where...
Sep 17, 2024 1:28 PM UTC
That article is for installations using SSO (Single Sign On).  Most installations don't use that. Do you use SSO with Windchill?
Your error message could be something to do with connections to the Publishing server (another server dedicated to Windchill Visualization).
As A.V. suggests, what has changed recently? Or have you always seen this error?
Sep 17, 2024 2:12 PM UTC
Hi, error is new for sure, I used creo view I don't remember when. as I said before I think trouble is on our information system who have new restriction . On Windows 10 PC nobody has the trouble?  (It not the first time a KB do the sh***) 🙂
vdegaonkar
Sep 17, 2024 3:52 PM UTC
What is the version of Creo View are you using? I would recommend try validating it with Creo View 11.0 as there are improvement in regards with SSO authentication as well if your organization restrict IE usage then it can lead to failure in communication between Windchill & Creo View. New improvement in Creo View 11.0 uses MS Edge for authentication purpose.
Refer Switch to Microsoft Edge for Authenticating with Windchill (ptc.com)
NOTE: Creo View 11.0 and later is no more supporting Windchill version prior to 12.0.2.0 any more.
Sep 19, 2024 7:55 AM UTC
I Using CreoView 5.1
TF_1130268910-MarbleAuthorAnswer
