Jul 10, 2023 6:36 PM UTC
Error When Returning to the Search Tab in the Browser After 20 Minutes
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.2
I get a Windchill Error when searching after leaving browser alone for a time period of about 20 minutes or more.
Here are the errors that I have in the browser window.
Status Code: 500
Message: Cannot restore "wt.query.SearchHistory. 198022734" because it no longer exists.
This isn't the only 12.1.2.2 issues we are seeing with the GUI.
HelesicPetr
Sep 7, 2023 6:27 AM UTC
Hi @BrianToussaint
I just clarify that  com.ptc.windchill.search.historyCount is a number of the record not a time how long the history is stored.
I guess that the issue is connected with session timeout how long is the login session active.
I would suggest to increase a timeout and you will see it it helps
CS74864 - How to configure Session Timeout in Windchill PDMLink
PetrH
jbailey
18-Opal
Jul 10, 2023 11:59 PM UTC
Out of curiosity, what type of authentication is being used? Username/Password? SAML?
Jul 11, 2023 1:19 PM UTC
We are using just a simple connection to Microsoft AD using http.
jbailey
18-Opal
Jul 11, 2023 1:24 PM UTC
Hmm.. does it happen with just you, or others as well? Did you test with a different browser?
Does your search history come back when you log back in?
If so, maybe there is something going on with the browser session... if not, maybe it is a DB issue?
ScottMorris
Jul 11, 2023 2:31 PM UTC
are you getting this error message?
Your session data has expired. Please repeat your action.
Jul 11, 2023 2:45 PM UTC
No I am not.  I do have this
com.ptc.jca.error <user name> - ---------- JCA Exception ---------- wt.util.WTRuntimeException: Cannot restore "wt.query.SearchHistory.198022734" because it no longer exists. Nested exception
I also had this afterwards and in a lot of different places in my logs....
 wt.system.out <user name>  - requestNonce:
18-Opal
Jul 20, 2023 11:23 AM UTC
Hello BrianToussaint,
This is Charles from PTC Technical Support in Europe, I will provide you assistance on this question.
Is com.ptc.windchill.search.historyCount set inside wt.properties ?
the default is 15.
Can you try setting some higher value?
KR,
Charles.
Jul 20, 2023 11:36 AM UTC
Hello Charles,
I searched wt.properties and that is not in there.  Do I need to set it at something higher?  I am guessing that value relates to minutes.
Brian
Nov 6, 2023 10:30 AM UTC
We noticed similar error in our Windchill version 12.1.2.0, but we have some test server with 12.1.2.4 and I don't see this error message there. So it looks like it is fixed in CPS04.
Balraj
Dec 8, 2023 7:01 PM UTC
hi,
I found this after I updated to CPS06 for a different issue.
Brian
