May 7, 2026 7:58 AM UTC
Error when using Windchill REST Services
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS17 Windchill QMS is not installed Can not access any rest API, with the error: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'relatedPersonnelOrLocations': Failed to introspect bean class [com.ptc.odata.windchill.entity.service.RelatedPersonnelOrLocationDelegate] for lookup method metadata: could not find class that it depends on; nested exception is java.lang.NoClassDefFoundError: com/ptc/qualitymanagement/masterdata/contact/QMSContact Here are the errors that I faced org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'relatedPersonnelOrLocations': Failed to introspect bean class [com.ptc.odata.windchill.entity.service.RelatedPersonnelOrLocationDelegate] for lookup method metadata: could not find class that it depends on; nested exception is java.lang.NoClassDefFoundError: com/ptc/qualitymanagement/masterdata/contact/QMSContact
18-Opal
May 7, 2026 9:06 AM UTC
Hi ​@Ennoconn,
Is QMS Module Installed?
Ennoconn4-ParticipantAuthor
May 7, 2026 9:25 AM UTC
QMS Module is not installed. Is there any way to remove or unreference QMS-related settings?
18-Opal
May 7, 2026 10:13 AM UTC
Which REST service are you calling?
