Feb 17, 2017 11:02 AM UTC
Error while creating a part when Security Labels are configured
I had configured Security Labels in my system. The method server is ready whenever i start and it doesn't crash. However few errors are being shown. PFB text of those errors.
ERROR [main] wt.access.configuration.SecurityLabelsHandler  - The UFID 'cn=Agreement Managers,ou=people,cn=AdministrativeLdap,cn=Windchill_10.2,o=xyz|Ldap.corp.xyz.com|Ldap.corp.xyz.com' is invalid.
ERROR [main] wt.access.configuration.SecurityLabelsHandler  - The UFID 'cn=US Persons,cn=Public,ou=people,cn=AdministrativeLdap,cn=Windchill_10.2,o=xyz|Ldap.corp.xyz.com|Ldap.corp.xyz.com' is invalid.
ERROR [main] wt.access.configuration.SecurityLabelsHandler  - There are non-fatal syntax errors in the security labels configuration file.
Please refer to the Method Server log file for details.
ERROR [main] wt.access.agreement.StandardAgreementService  - configureAgreementService: The group defining the agreement managers was not set properly in the Security Labels configuration file.  This has the effect disabling the agreements UI and prevents write access to agreements for all users, including administrators.  Existing agreements will still be evaluated during access checks.
and then the method server gets ready.
However when i navigate to a Product and then create a part i am able to create the part successfully but i am not able to view the part created in the product folders. An error is being reported in the Method Server Log like
ERROR [ajp-bio-8010-exec-1] wt.access.evaluation.report wcadmin - "Administrator" does not have Read permission for "Part - 0000000003, ABC, A.1 (Design)" in Administrative Domain "Site, Organization - Demo Organization, Product - GOLF_CART /Default".
ERROR [ajp-bio-8010-exec-1] com.ptc.mvc.controllers.ExceptionController wcadmin - message : You do not have access to this object or it does not exist.
error:-------------javax.servlet.ServletException: wt.util.WTException: You do not have access to this object or it does not exist.
Caused by: wt.util.WTException: You do not have access to this object or it does not exist.
  at com.ptc.windchill.enterprise.navigation.RedirectUtility.redirectToNewAction(RedirectUtility.java:240)
  at com.ptc.windchill.enterprise.navigation.RedirectUtility.redirectToNewAction(RedirectUtility.java:171)
  at com.ptc.jca.mvc.components.TypeBasedRedirector.handleGetContextObjectException(TypeBasedRedirector.java:86)
  ... 39 more
ERROR [ajp-bio-8010-exec-1] wt.servlet.ServletRequestMonitor.request wcadmin - 2017-02-17 16:22:03.992 +0530, 2uuz52;iz9owcyi;7852;uxo3jz;2039, wcadmin, 10.76.51.102, /Windchill/ptc1/tcomp/infoPage, oid=VR%3Awt.part.WTPart%3A138806&portlet=component, POST, 501, 0.0624004, 0.097618893
ERROR [ajp-bio-8010-exec-1] wt.access.evaluation.report wcadmin- "Administrator" does not have Read permission for "Part - 0000000003, ABC, A.1 (Design)" in Administrative Domain "Site, Organization - Demo Organization, Product - GOLF_CART /Default".
ERROR [ajp-bio-8010-exec-1] com.ptc.mvc.controllers.ExceptionController wcadmin - message : ATTENTION:  Secured Action. You do not have the necessary authorization for this operation. Contact your administrator if you believe you have received this message in error.
error:-------------wt.util.WTRuntimeException: ATTENTION:  Secured Action. You do not have the necessary authorization for this operation. Contact your administrator if you believe you have received this message in error.
All these operations were performed in Site itself. Can you please let me know how to debug this error.
Thanks and Regards,
Aditya Achanta
aachanta15-MoonstoneAuthor
Feb 20, 2017 4:21 AM UTC
Hi All,
If anyone is aware of how to resolve this error kindly let me know about the same.
Thanks and Regards,
Aditya Achanta
