May 24, 2022 1:32 PM UTC
Error while installing Windchill 11.1
I am getting the below error after running Windchill 11.1 psi.
SCU installer appears to have failed to start. its ptc and / XML logs are missing.
Please provide the solution
Thanks in advance
Vipul
May 25, 2022 1:30 PM UTC
 Hi Vipul,
Read this article - "SQL Server Configuration Utility (SCU) fails to install when executed from Windchill PDMlink 11.2.1.5": https://www.ptc.com/en/support/article/cs333883
