Nov 29, 2011 7:02 AM UTC
Error while starting Windchill 9.1
While trying to open windchill homepage using localhost,
The following error was encountered:
Unable to determine IP address from host name
The dnsserver returned:
Name Error: The domain name does not exist.
Please reply me.
Nov 30, 2011 2:55 PM UTC
Is Apache running? Try hitting it without the windchill application name with just http://localhost. When you try with the webapp name, do you at first see the PTC splash screen? Make sure your wt.property java.rmi.server.hostname is added to your hosts file as localhost.
Dec 1, 2011 7:02 AM UTC
Thanks for reply.
Apache and tomcat are working properly and also i am getting PTC splash screen.
Hostname entry is present in hosts file as localhost but i dont have an IP address as 127.0.0.1 because while installing it was not accepted.
So please reply.
Dec 1, 2011 2:32 PM UTC
I'm confused.
Assuming your app name is Windchill, enter http://localhost/Windchill
1. Do you see the splash screen, then an error?
Assuming your app name is Windchill, enter http://127.0.0.1/Windchill
2. Do you see the splash screen, then an error?
3. What property do you have in wt.properties for java.rmi.server.hostname?
4. What do you have for ServerName in Apache's httpd.conf?
5. What name does Apache use for the BalancerMember in ajpWorkers.conf?
