Jun 20, 2014 12:34 PM UTC
error with loadbalancing configuration
Hi
I am getting below error when trying create replica schedule.
2014-06-20 13:44:50,400 ERROR [ajp-bio-8011-exec-1] com.infoengine.procunit.adapter.ConnectionManager - Load balancing failed.
2014-06-20 13:44:51,414 ERROR [ajp-bio-8011-exec-1] com.infoengine.procunit.adapter.ConnectionManager - Load balancing failed.
2014-06-20 13:44:51,414 ERROR [ajp-bio-8011-exec-1] com.infoengine.IeServlet - bad HTTP header: HTTP/1.0 400 Invalid request
java.io.IOException: bad HTTP header: HTTP/1.0 400 Invalid request
at com.infoengine.object.ContentHeader.<init>(ContentHeader.java:127)
at com.infoengine.object.ContentHeader.newContentHeader(ContentHeader.java:168)
at com.infoengine.object.IeMultipartInputStream.<init>(IeMultipartInputStream.java:294)
at com.infoengine.IeServlet$RequestDispatcher.run(IeServlet.java:498)
at com.infoengine.IeServlet.doGet(IeServlet.java:247)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
it is appearing after I configure the environment as cluster env but not sure what went wrong in cluster configuration,
other things are working fine.
any guide on this to solve would be help ful.
Jun 25, 2014 7:32 PM UTC
Can you post the full MS log containing the error as well as the wt.properties files from your cluster nodes? That way the community can take a look at your cluster settings and see if we can see any problems.
ManojC1-VisitorAuthor
Jun 26, 2014 10:39 AM UTC
it is resolved now. thank you for the reply.
There was problem in cluster configuration, we corrected it then it started working fine.
Jun 27, 2014 7:12 PM UTC
Can you let us know what configuration was incorrect, in case someone else see's this same issue in the future?
