Jan 31, 2025 5:16 AM UTC
ESI Distribution Target Types
I have a requirement where I need to connect Windchill and Oracle Cloud using ESI Module. In the Distribution Target type, I was exploring the options "File" and "Oracle Applications". I know that the File type is used when we want to transfer the XML content to the downstream system. When should we consider Oracle Application type?. Since I could not find a lot of information on this, requesting your inputs.
TIA.
avillanueva
23-Emerald II
Jan 31, 2025 1:39 PM UTC
I use File since I am exporting the XML file to a local folder. It indicates how you are connecting. For example, FTP asked for FTP connection information. If you are wanting to connect directly to the Oracle ERP, then choose Oracle. I believe those direct and bi-directional connections require the full ESI module and Tibco connector for these ERP systems.
Catalina
Community Manager
Feb 7, 2025 1:33 PM UTC
Hi @Sha11,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
